I have a 92 hyundai elantra ...I rebuilt the transmission, put a new starter in at along with a new alternator.... but it wont start unless it's jump started. whats the deal? anyone know? Im not car smart!
Oh and supposedly my battery is new, it's been tested and they said it's fine... nd it isnt the problem....
:rolleyes: :rolleyes: :mellow:
Check de Motor ignition Point.
Regards
Selenico77
[snapback]1296[/snapback]​
You might want to check the battery cable too. I was having the same problems with my '97 Elantra. New battery, new alternator, new cable ends and still no starting. I took the car to a mechanic fried and the first thing he said was to check the cables. Sometimes the break just from age. Mine was broken in hale and i could not tell because of the cable covering. Try that and good luck.
Does it want to crank over at all, with the original battery in it before you have to jump it.
Are your ignition lights bright or dull.
Because the first thing that I can think of if you have to jump start it is that the battery has failed.
Was the battery load tested, beacuse the battery can hold voltage but have very low cranking amperage.
