Hello everybody, I am experiencing the last week a strange problem. The power windows of the 2.9 CRDI Terracan are able to be operated only from the drivers switch. I took out the drivers switch out of the door panel and used some contact cleaner but still no improvement. Do you have any idea what could be the problem? Thank you
yes I have had the same problem and changed switches from side to front can only control from drivers side .. I believe there are some companies that re work the old switches ..if i find out who the are i will post their name
You should try cleaning the switch yourself using some electrical contact cleaning spray. It didn't work for the OP in this thread but it has worked for quite a few folk on the various forums here.
