1 - 1 of 1 Posts
My first time at this forum, hello from Perth WA.
Have removed the outer engine cover and Turbo intercooler, tried to remove the other insulated engine cover, sadly bolts turn but will not release, was trying to get to the CRD Fuel Pressure sensor to refit a Diesel Chip, because of my limitation of room trying to pry off the sensor cable and the actual Pressure Sensor broke off from the screw in sensor that fit's into the end of the CR.
Have sourced a new / second hand one and to date no joy, will be at it tomorrow, yes New Years Eve ?
Some Questions to consider:
Is there another type of sensor switch that is compatible with the one mentioned above.
Could an auto electrician assist in repair.
What are my options.
Thanks for taking the time to read my sad story.
Regards
Denis O'B
1 - 1 of 1 Posts
