Hi,
We use the #1 and 2 memory sets. My setting does tilt the steering wheel down to where I have it set, but it does not telescope it out to where I had it when I set it. I have tried it numerous times over the past few years, and it is always the same result.
So, is my car not working correctly, or is this just the way the 2008 Veracruz works? :confused:
it should telescope it to your setting.
have you tried to reset your memory button?
My car was doing the same thing. I took it to the dealership. Cost $100 to hook the car up to their computer and another $98. The new part was only $9, the rest, labor to tear the steering column apart to replace the defective part. So $200 total.
what i did...was after i had it where i wanted it..i pulled the fuse. less wear and tear on a motorized part that i found wasn't really necessary. i can get in and out quite easily without it always moving. i drive it 95% of the time...and wife can just use where the wheel is and adjust the seat to the wheel, as well as the pedals.
