Status
Not open for further replies.
1 - 9 of 9 Posts
Hi Guys, I wanted to upload all the TSB pdf files i have for the Tucson in one place.
These documents are my property and i have the right to share them as i see fit. Just a little release note in case anyone sees all these in one place.
Some of these will not apply to you year and some will apply to more than just the Tucson so read them carefully.
And please don't go running into your dealer with one of these in your hand if you have one of the issues listed on them. I am sure no one in here will do that but just a note for the CrAzIeS.
Enjoy & comment if i missed something you need.
View attachment LEATHER STEERING WHEEL CLEANING TSB lol.pdf
View attachment Intermittent no engine crank no engine start in P or N with or without DTC PDF.pdf
View attachment Impossible engine start in P or N TSB.pdf
View attachment HYUNDAI SPECIFIED ATF AND ADDITIVE USAGE PDF.pdf
View attachment AUTOMATIC TRANSAXLE HARSH AND OR DELAYED SHIFT TSB.pdf
View attachment Customer concern of an erratic or unresponsive fuel gaugeTSB.pdf
View attachment ETC THROTTLE BODY CLEANING HARD START TSB.pdf
View attachment ATF Fluid Level Checking Procedure TSB.pdf
View attachment Various Shift Lever Issues TSB.pdf
View attachment Outside Rearview Mirror Noises TSB.pdf
View attachment ALIGNMENT SPECIFICATIONS TSB.pdf
View attachment TWO TYPES OF BATTERY WET CELL & AGM Batteries TSB.pdf
View attachment Cabin Air Filter Blower Motor Service Precautions TSB.pdf
View attachment IPHONE POD USB DATA CABLE TSB.pdf
View attachment USE OF AFTERMARKET ENGINE OIL FILTERS TSB.pdf
View attachment AUTOMATIC TRANSMISSION OIL COOLER FLUSHING TSB.pdf
View attachment CLEARING DIAGNOSTIC CODES FROM THE BLUE LINK SYSTEM TSB.pdf
View attachment ABS PUMP SELF-CHECK NOISE TSB.pdf
View attachment NAVIGATION TOUCH SCREEN RECALIBRATION TSB.pdf
Discussion Starter · #8 ·
1 - 9 of 9 Posts
Status
