Status
Not open for further replies.
1 - 1 of 1 Posts
TSB's
Hi Guys, I wanted to upload all the TSB pdf files i have in one place. These are for our YF owners like the title says. I know half of these may be scattered around this site so here are the ones i thought were important enough for us to have. There also some others that are not TSB related but are informative.
These documents are my property and i have the right to share them as i see fit. Just a little release note in case anyone sees all these in one place.
Some of these will not apply to you year YF and some will apply to more than just the YF so read them carefully.
And please don't go running into your dealer with one of these in your hand if you have one of the issues listed on them. I am sure no one in here will do that but just a note for the CrAzIeS :hyper: in here.
Enjoy & comment if i missed something you need.
PS: Will only let me put 10 per post and there are 30 so i have to split them up.
View attachment YF Steering Noise TSB.pdf
View attachment TPMS (TIRE PRESSURE MONITORING SYSTEM) TSB.pdf
View attachment Intermittent no engine crank no engine start in P or N with or without DTC.pdf
View attachment Battery replacement 2 types.pdf
View attachment AUTOMATIC TRANSAXLE SOLENOID DTC.pdf
View attachment AUTOMATIC TRANSAXLE HARSH AND OR DELAYED SHIFT.pdf
View attachment ALIGNMENT SPECIFICATIONS YF.pdf
View attachment SONATA HEADLIGHT AIMING PROCEDURE.pdf
View attachment Removal and Installation of cruise controll switch.pdf
View attachment Brake System Bleeding.pdf
View attachment LEATHER STEERING WHEEL CLEANING LOL.pdf
View attachment YF SONATA STEERING CALIBRATION.pdf
View attachment Follow the guidelines outlined in this bulletin to inspect and clean or replace certain componen.pdf
View attachment AUTOMATIC TRANSMISSION OIL COOLER FLUSHING.pdf
View attachment ABS PUMP SELF CHECK customers may describe as a rattle, groan, growl, gurgling, or buzz.pdf
View attachment NAVIGATION TOUCH SCREEN RECALIBRATION.pdf
View attachment SONATA PANORAMIC SUNROOF NOISE.pdf
View attachment Customer concern of an erratic or unresponsive fuel gauge.pdf
View attachment ETC THROTTLE BODY CLEANING.pdf
View attachment USE OF AFTERMARKET ENGINE OIL FILTERS.pdf
View attachment HYUNDAI SPECIFIED ATF AND ADDITIVE USAGE.pdf
View attachment CLEARING DIAGNOSTIC CODES FROM THE BLUE LINK SYSTEM.pdf
View attachment ENGINE COMPARTMENT RATTLE DURING.pdf
View attachment C R A N K S H A F T P U L L E Y B O L T I N S P E C T I O N TSB.pdf
View attachment GLOVE BOX RATTLE CREAK NOISE TSB.pdf
View attachment FRONT PASSENGER AREA BODY CREAK NOISE TSB.pdf
View attachment HEADLINER INSPECTION AND REPLACEMENT TSB 2011.pdf
View attachment REAR LOWER CONTROL ARMS TSB.pdf
View attachment shock when shifting into Drive or Reverse TSB 2011.pdf
View attachment Reset Blue Link DTC codes.pdf
View attachment RATTLE BUZZING SOUND DURING INITIAL COLD START ORWHEN ACCELERATING FROM LOW ENGINE RPM TURBO ON.pdf
View attachment Severe Service Defined.pdf
View attachment STEERING WHEEL TRIM REPLACEMENT TSB.pdf
View attachment ALIGNMENT SPECIFICATIONS - 2013 ONLY TSB.pdf
View attachment BACKUP CAMERA AND CAMERA MODULE COMPATIBILITY TSB.pdf
View attachment brake noise due to improperly adjusted parking brakes TSB CANADA ONLY.pdf
View attachment Canada 2011 YF Engine Compartment Rattle TSB.pdf
View attachment CANADA 2011 YF Front Body Creaking Noise.pdf
View attachment Compatible USB IPOD cable.pdf
View attachment Head Lamp Aiming Instructions.pdf
View attachment Head Lamp And Fog Lamp Aiming Point.pdf
View attachment Keyless Start System - Stop Lamp Switch Adapter Harness TSB.pdf
View attachment Parking Brake Shoe Clearance Adjustment.pdf
1 - 1 of 1 Posts
Status
