I have a 2014 i30 premium and not happy with the sat nav. What bugs me is the lame notice that appears when you want to quickly enter a destination. It takes an exasperating amount of time for the "agree" to go solid so you can proceed.
Can this annoying feature be removed or if not, shortened. Also has anybody else had a problem with the auto headlight sensor. On auto my headlights are permanently on even on a sunny day.
Thanks,
TC
The lights being permanently on is a symptom of a faulty light sensor. When the signal from the sensor is implausible the lights are switched on. The system is designed to work like that so the lights wont switch off if the sensor fails at night.
Obviously, they will also be on permanently if you cover the sensor so it can't see the light...just covering all the bases here.
