1 - 11 of 11 Posts
Should there be this much soot in the tailpipe of an engine with less than 5600 miles on it ? Seems a little bit too much.:surprise: The other car I checked had very little soot and has almost 50,000 miles on it. That engine is EFI not GDI.
It's running rich.
00000732
Best practices for requesting help:If you haven't done so fill in your vehicle info and profile page. At upper right corner under the search box click on user cp (it's your control panel)
This info will show up to the left under your user name and is very helpful.
BE SURE TO ADD YOUR LOCATION SO WE KNOW WHAT MARKET YOU ARE IN.
  • Be sure you are in the correct forum for your vehicle.
  • Do a search for your problem. A lot of stuff has been asked and answered.
  • Do not double post for the same problem.
  • Give the model year....Engine size...transmission type (auto or standard)
  • Take a single issue at a time. Posting multiple issues at once will get convoluted very quickly
  • VIN number can be very helpful
  • Vehicle history can be good. How many miles. If not bought new, how many have you put on it.
  • Describe the problem best you can. If a noise can you get a sound or video file
  • Tell us what has been done, if anything, thus far. If tests have been performed give actual results not OK or passed. If scanned for codes the actual code(s) not O2 sensor or MAF, Etc.
  • If the vehicle has been to a repair facility it would be nice if you could post a picture of that invoice/bill
  • If your vehicle is under warranty you should have the dealer check it out. If it's a problem they see many times they will generate a safety recall of TSB. This is how they know of the problem.
Thanks,
Welcome aboard.
Been doing some research. Looks to be normal for the GDI and other direct injection engines. Will keep an eye on it. We use top tier gasoline. Thanks for your input.
You said your engine was NOT GDI.
What's the truth?
Also, are you in northeast US, Canada, Australia??
Some dry soot is OK for GDI, oily soot no.
The last few times I've bought used cars one of the things I check is the tailpipe.
An oily pipe typically means the engine is an oil burner.
A bad case will have deposits on the bumper and valance around the pipe.
I have this habit of looking over other cars when walking through a parking lot, walking the dog etc.
I see an abundance of Euro luxury cars and Subarus with dirty pipes.
My previous Toyota Matrix had a totally clean pipe, bare metal on the inside and no oil consumption.
Discussion Starter #11 (Edited)
More soot . Wiped fingers inside tail pipe . I'd expect this from a diesel . That's why the SMOG is a 3 on the window sticker .
1 - 11 of 11 Posts
