1 - 11 of 11 Posts
I have a 2013 Elantra limited and yesterday while driving I felt a small jerk, the engine light flashed and the RPMs dropped to zero. I was driving without issue at higher speeds (50-60). Then, after a stoplight, the car was running but starting sluggishly as though stuck in a higher gear. I then switched to shiftronic (or whatever it is called) and the dash indicator showed a number 6, but it would not shift out of that gear. I parked and stopped. Turned off the car and then back on. Everything works again. The fact that the tachometer and the shifting both stopped and then recovered makes me think that it’s an electrical or computer issue. Anyone else experience this? I have over 85000 miles on it, and I am hoping it is not the beginning of a big issue.
Did we scan all the onboard modules for fault codes ?
I have a 2013 Elantra limited and yesterday while driving I felt a small jerk, the engine light flashed and the RPMs dropped to O. I was driving without issue at higher speeds (50-60). Then, after a stoplight, the car was running but starting sluggishly as though stuck in a higher gear. I then switched to shiftronic (or whatever it is called) and the dash indicator showed a number 6, but it would not shift out of that gear. I parked and stopped. Turned off the car and then back on. Everything works again. The fact that the tachometer and the shifting both stopped and then recovered makes me think that it’s an electrical or computer issue. Anyone else experience this? I have over 85000 miles on it, and I am hoping it is not the beginning of a big issue.
I'm sure we will be able to help you with that. Start by scanning the computer network for codes.
00000732
* Do a search for your problem. A lot of stuff has been asked and answered.
Thanks,
Welcome aboard.
Scanner says 0 dtc and noSupp. Not sure how to access history.
Should be able to access current codes as well as non current or history codes. Look at the screen before entering the system...should be a screen to see history codes.
Discussion Starter #8
Okay. It happened again twice. Sensor pulled a PO335 or P0335 which apparently is a crankshaft position sensor according to google. Does that make sense with the ones in the know in this forum? Thanks in advance.
Replaced a handfull of crank position sensor already on UD/MD Elantra,, fairly simple part swap.. part replaced from under side,, unplug from top
P0335 is common Hyundai CKP fault code
abcdefg
Sounds like you found the problem.
1 - 11 of 11 Posts
