1 - 11 of 11 Posts
Well the gf has a 2003 Tibby, and she went to use the sunroof. The first button on the roof doesn't work at all. Weird.
The second button works, but the roof only lifts, and doesn't go all the way back, just maybe 3 inches or so.
Is there something I can check, is the motor for it fried?
Any insight would be awesome, thanks. :)
there is 2 switches, one is for just tilting the sunroof which that sounds like it works and the other is for putting the sunroof back. Sounds like the button needs to be replaced, mine is starting to go out also.
with roof closed and key to off
hold the two buttons at the open position and turn the key to on
this will reset the moonroof, could also fix the problem.
LightingTib is right. The same thing happened to me. I read the owner's manual and that did the trick no problem.
Mine was a switch problem too. Guess it's common for them to short out and need replacement. Try the other option first though. That would be nice.
Where can I find the sunroof's switch replacement?
A new replacement part ??
Visit Hyundai dealer of choice' parts dept,, fella will look it using your VIN, and gladly order switch from Hyundai Motor Company region PDC for you.
1 - 11 of 11 Posts
