I own 2000 Hyundai Trajet and i need to change many things in the car.
Suffers as follows:
use Lead Replacement Petrol (super).
The engine sometime coughs, especially at high speed, there is no more power
under the pedal and it makes a loud bang (the exhaust pipe) if I press the clutch pedal.
Does this have anything to do with the petrol?
Should I use after-run oil?
thanks a lot for your help.
your car needs the proper checkup.Did you ever service your car.if not!then go for servicing.I know it will cost you a lot ...but if your car is under warrenty scheme then you don't have to invest money on the car.Still if it not under warrenty scheme do go for servicing....
and don't apply your own mechanics on your car..........
i hope you must have understand what i want to say.....
bye
Suffers as follows:
[snapback]496[/snapback]​
