My Check Engine light is on and the transmission won't shift out of 3rd gear. From my digging around online, I found out this is a "limp home" feature of the electronics, and the problem is likely one of a few malfunctioning sensors. I've recently had a dead battery, a lot of lightning storms, and I drive through lots of huge mud puddles. It could be just about anything. The local shop were scratching their heads about it. What should I be doing with this thing? Towing it to the dealer or what? Is this a simple fix or an expensive problem?
MIL....................... SCAN IT
Stuck in 3rd --> trans control default for trans concern,,
Suspect you find a TCM request for use of MIL to tell you we have problem,, and need to go into transmission control to recover DTC to know which circuit TCM has seen to have fault
Easy
