Hey guys,
I have a 2003 Hyundai Sonata base with a 2.4L I4 engine. I recently had some electrical problems which lead to replacing the alternator. We had the alternator tested and they agreed that it was fried.
We installed the new alternator and the car (after charging back up the battery) started just fine.
The car ran fine for the first day, but now is displaying the check battery light once more. We tested the battery and it shows that it is holding at 100% charge (and it should as it is less than a month old.) We also detached the battery after starting the car to make sure that the new alternator was working properly, and it seems to be.
The speedometer has stopped displaying the correct speed. It will go up to about 25 MPH then stop until I turn on the AC, then it will jump up to the correct speed and run properly for a while after that. Eventually it stops working again. I have also noticed that when I turn the AC unit on the battery light goes away momentarily then eventually lights back up.
I assume it has something to do with the belts, but it looks like the replaced those correctly. I also thought that it might have something to do with the cables we reattached but all of those seem to be attached correctly as well.
What else could be the problem?
Thanks in advance!
Thanks in advance!
