1 - 1 of 1 Posts
okay im not sure if you guys remember my problem i was having with my usb port.. heres a quick refresher.. when i pulg a cord into the usb and then into my phone, it doesnt connect and i get a constant on/off charging from my phone almost as if the powers cutting in and out.
ive replaced the whole usb jack assembly with a brand new one from hyundai and it is still the same problem.. i plugges an aux cord into it and that is working fine.. its not a big deal for me but im curious if anyone here as had this problem and/or a solution?
i did try to side strip the blue wire coming from the jack when i installed my led cup rings but i ended up cutting the wire and i soldered the wire back together along with the wires from the led cup rings.. i didnt try the usb before but does anyone think this could be the cause of the problem?
1 - 1 of 1 Posts
