Status
Not open for further replies.
I have a 2002 Santa Fe 2.4L with a stick shift. Today, I had a problem with the stick shift not shifting from first to second gear. When I tried to shift into second, it jammed. I had to drive in first and then shift to third a couple of times, and then it seemed to straighten out, and I could shfit normally. On the way home the same thing happened.
I cannot figure out if is the clutch or the transmission or something as simple as the clutch needing fluid. I hope it is not something wrong with the drive train.
Anyone else have this problem with a stick shift?
Thanks,
Nellie
Status
