2008 Veracruz
Yesterday, two problems occurred at the same time. First I the airbag light came on. Then a short time later I noticed that the steering wheel tilt quit working. It is now stuck in the down position. I will telescope fine...but will not tilt. Are these two interrelated? If so, what could be the possible causes? If not related...what could be the causes? And I called Hyundai..and my Veracruz does not fall within the clockspring recall covered date or VIN categories.
Thanks
Hi yukong. Did you finally found out what was keeping the airbag lit on? I just started having the same issue today. Not the steering problem since mine doesn't have electric tilting
Enviado desde mi Redmi Note 4 mediante Tapatalk
