So, what's your question?
At first I was very skeptical about the post; mostly due to the multiple postings and the nature of the story. After reading her follow-up posting, I figured that the post was real. That said, we really do not know what caused the issue at this point. It could be road hazard damage, or it could be a faulty part.Well, I found this case filed to NHTSA.
http://www-odi.nhtsa.dot.gov/complaints/
ODI ID Number : 10322666
More than likely what you have is a defective tire with what's called a "radial pull". It's rather common. My car has a slight drift to the right. Have your dealer check your tires and ask for a new one. Since you have such low miles, there shouldn't be an issue with a new tire mixed with older tires.Newbie to such forums.
I just bought a 2011 Sonata SE in Austin, TX last wednesday. I have driven about 240miles on the car so far.
Right from the day I picked up the car, I noticed that the steering was never centered when I let it free (the steering center is about half an inch off to the left). It pulls the car to the left unless I counteract. It kind of gets on the nerves because I constantly have to keep the steering pushed to the right. I am taking it to the dealer on wednesday. I have been reading a lot of postings online about same problems faced by other 2011 sonata owners. Any verdict on what is wrong with these cars?
I really love this car and hate to find out the design itself was wrong.
Yes she had a problem as viewed on you tube. However no one has seen, heard or proven there were other vehivcles at the same Dealership with the same problem. As of now the problem appears to be a random part defect or a poor harness connection. Several others have reported similar PS failures and they were all repaired immediately. Corrections were replacement or repair of steering column harness.I read that post on Edmund's yesterday. I was not sure how much credence to give to it. Since she has filed a report on the NHTSA website and the fact that the Gov't can track it to a specific dealership, I would think that there is some credibility to the claim. I am not saying that it is a specific defect.
If I were at Hyundai and these claims are true (that they red flagged 5 of 6 vehicles), I would be in immediate contact with the NHTSA to inform them of a potential issue, a team has been assigned to diagnose a possible defect, and a recommended resolution if warranted. Hyundai does not have the customer base to afford what happened to Toyota. They would save more face by acknowledging a potential problem exists and they are fully investigating. It is a more proactive approach instead of brushing it under the rug. If it is a bolt, you are talking nothing more than a $1 part and labor costs that are already being paid. This is not a financial issue.
Also, if you haven't already done so, make sure your tires are properly inflated.
Guys,More than likely what you have is a defective tire with what's called a "radial pull". It's rather common. My car has a slight drift to the right. Have your dealer check your tires and ask for a new one. Since you have such low miles, there shouldn't be an issue with a new tire mixed with older tires.
I have had dealers balance until they are blue in the face and not diagnose the problem. You are trying to say its the steering, which it might be. One of my solutions was not solved until I had them pull the tires off the rims and free spin the raw rim to realize it was out of round. Point? Dont lose focus and pigeon whole yourself into what you think the solution should be...Guys,
One round of wheel alignment and tire pressure adjustment later, the problem still exists. I still only have about 263 miles on the car. I have read a lots of forums and everyone seems to point at the cheap hankook tires used on the sonata but some say that could be related to the steering column mounted Electiic power steering (unlike other models).
I am going to talk to the dealer again and if they cannot find a way to fix this, I will write to hyundai directly. Any suggestions ??
This is certainly going to take multiple iterations with the dealer and try out different things each time. But I am just disappointed that with so many sonata owners complaining about the left pull issue, Hyundai has not diagnosed the root cause. I am not going to let the dealer get away without fixing my car. I am just scrounging for the absolute fix if anyone has found one so that I can have the dealer test it out.I have had dealers balance until they are blue in the face and not diagnose the problem. You are trying to say its the steering, which it might be. One of my solutions was not solved until I had them pull the tires off the rims and free spin the raw rim to realize it was out of round. Point? Dont lose focus and pigeon whole yourself into what you think the solution should be...
Sometimes, also, you might want to do some work by yourself. If you rotate your tires, does the symptom change...?
Given how many Sonata owners out there and the small sampling we see here, not so sure its a wide spread problem. I have read through the threads I can find and dont see any real diagnosis work being done. Sometimes you have to take the lead and do something on your own to show the dealer you are serious. Sucky? Yes. Dealing with dealers is almost like dealing with an infant sometimes. Or maybe its like a teenager..? They know it all until you prove them wrong? :whistling:This is certainly going to take multiple iterations with the dealer and try out different things each time. But I am just disappointed that with so many sonata owners complaining about the left pull issue, Hyundai has not diagnosed the root cause. I am not going to let the dealer get away without fixing my car. I am just scrounging for the absolute fix if anyone has found one so that I can have the dealer test it out.
Try rotating the tires and see if the problem goes away or changes direction.Guys,
