The battery is good at aboit 85% had new cable to battery terminals tightened and one replaced. Thinking connection was bad with corrosion .That did not solve problem. Over last 2 days there was intermittent problem of NO CRANK, and No turnover , did start after awhile .
But now no solenoid noise no turnover nothing ....However the car lights and clock really go down to nothing when I try to crank it now ...
Last time I started did get error codes at Auto Zone ...had been driving in OD OFF Mode to avoid some rough shifting.
Says probable transmission speed sensor needs replacement.
So is this probably just Solenoid Starter .
Car always starts in 3 to 5 seconds .
And did last time I started it today .
Seems like a short somewhere stopping the turnover...and no click from solenoid.
For now just want to get it started and drive ...then have sensor replaced ...
Hopefully transmission errror will not stop it from turning over , correct ?
