1 - 9 of 9 Posts
I have a 2006 Accent. I had repaired the timing belt and then found other issues. i replaced the timing belt pulley, spark plugs, points and head gasket. The vehicle will turn over but will not start. What do I check now or repaired?
Was the engine running o.k. before you did all that work or did you "repair" the timing belt because it actually broke while the car was running? What else have you done so far to try to diagnose the cranking no start?
2014 SFS 2.4l
Scan for codes and retrace everything you did, unplugged/replugged... etc. This sounds like basic Crank No Start diagnosis you can find on many posts on this forum to rule out at least the basics. Scanning the modules would probably be the first thing to do.
Check the connectors first. sandpaper and tighten the ground wires, if that don't work, it's most likely that the timing is off
1 - 9 of 9 Posts
