Hi guys,
I've got a 2005 1.4L Getz and it's had a grinding noise on start up for a while, then a few days ago it decided to not start at all, the battery is reading 12.7V and it can be push started.
I've just taken off the starter motor to inspect it and just need a second opinion on the condition of the flywheel and starter teeth.
Please see attached pics.
Thanks in advance
Your flywheel ring gear looks OK to me, but your starter pinion bush doesn't look too great.
2007 Honda CRV
Do you mean it will not start that it will not crank??
If it doesn't engage to crank engine then may need new starter.
2007 Honda CRV
Yeah didn't crank at all, no click, nothing. I've ordered a starter so hopefully it fixes it.
From your pictures, it looks like the starter gear took the major toll of the grinding
The flywheel gear teeth also look beat up.
However it should still work with new starter.
Good luck
