Hi
I have a 2004 Elantra. I hear suealing(not knocking) noise when I turn the vehicle left and right from a stop position, the noise goes off when car moving straight. Does anybody know what this problem is?
Thanks
2004 to 2010 is 6yr, add for earlier production date...
Aged belts..
P/s is driven via the water pump, so you first need to make sure the alternator/water pump belt is good and tight.. then tighten the P/S belt..
Look at the A/C belt, is it all cracked ?? Tell tale sign you have not replaced timing belt, as we do belts with timing belt replace, price of belts on re-assembly.
