2005 Hyundai Tucson 2.0L 4cyl automatic transmission. Okay so my wife is driving home from work and her speedometer suddenly went from 65mph-0 then back up to 65mph. The next day I took it for a drive and the speedometer wasn’t working for the first few minutes then suddenly it started working again. I assume it’s either a loose connection or failing sensor. When I looked it up it says it has 2 sensors. An input and an output sensor. I have no idea where they are located. I think I found 1 next to the spark plugs but not sure if that is the input or output. Any help would be greatly appreciated. Thank you.
note that I just replaced a leaking VVT solenoid the day before this started. I don’t believe that has anything to do with the speedometer but if it does let me know. Thank you.
