Hello,
I have a 2012 2WD Santa FE GLS. I have my traction control, abs, and downhill assist lights all stuck on the dash. From reading forum posts it led me to think my speed sensors were bad and in fact my code reader said my rear left and right speed sensors were bad. I ordered new ones, so i thought, but all i received was the cable harness. I checked continuity on both cables in the vehicle and they both were fine from one end to the other. Where the hardness plugs into the speed sensor it looks like it's all one piece (like a hockey puck). Is that all one piece or does the speed sensor pull out of that "puck". In which case, does anyone know how to get it apart and what the replacement part number is?
Thanks!
Scanner doesnt know if if sensor is bad or not....Module see fault in particular circut, it store DTC for you to find,, then diagnose problem circuit to find if circuit fault, or part fault..
