1 - 13 of 13 Posts
2021 Santa Fe, Quartz White/Tan SEL with both packages
2021 Santa Fe, is the speed limit display only in the Nav area or is it also shown at the digital cluster (possibly when Nav is off)?
Thanks
Thanks. My wife swears we had it there also, in addition to the Nav. Ours is an SEL with both extra packages. How/where did you access he option?
I’m getting off work in about 30min-1hr. I’ll look and let you know.
It's definitely an option. I turned it on in mine the other day.
Thanks, as you can. Something went on the other day, also the clock went off DST. That I found out how to do, just not know why it did it .
Ok, so I Setup > Vehicle > Cluster > Select Theme > Content Selection
Then click Traffic Signs.
Hope this helps
Discussion Starter · #8 ·
Thanks. I'll go out in a bit ands see what I can find.
2022 Santa Fe PHEV Phantom Black Pearl
You probably swapped from the 'Guest' to one of the Profiles (perhaps setup a profile for you) and it sets all the defaults. Effectively you have to go through everything and check it. Mine went back to kph even and had to set that up. Would be nice to 'copy' the settings from one profile to another (maybe it's an option... didn't see it...)
Discussion Starter · #10 ·
I think we have a BINGO! Had not thought of that. It should be the answer. Yep originally everything set up for the wife, I'm the second profile/guest.
Thanks.
2021 Santa Fe Limited Hampton gray black interior
So I tried this and it worked but I noticed the speed displayed is usually not the correct posted speed limit. Not really reliable in a city where speed limits change constantly, but possibly good on an interstate if you're in a state you don't travel to often.
Yeah, unfortunately it’s navigation system based and not detected via the front camera like on the Tucson.
Discussion Starter · #13 ·
Thanks for all the response. Went in and updated/listed my profile, that was the answer.
1 - 13 of 13 Posts
