Does anyone know what the offset, center bore, and width of the 2011 SE's 18" wheels are?
I did a search, and I think what I saw was 18x7.5, +46 offset, and 67.1 CB.
Can anyone confirm?
Actually my goal is to fit 20x10.5 in the rear... I know it will need a bit of a stretched tire, as well as a bit of fender work... the question is... how much?if that's what u saw then that's right.
however this is not the size u want to stick with, a sunken look makes the car look less aggressive and makes the
wheel look smaller.
here is 18x8 +40, so about 12mm more poke compared to stock 18" size. It will be for sale if you want it in so cal area, I'm waiting on my
next set of wheels to come in.....as u can see, it looks hot! actually looks a lot bigger than oem 18".
