1 - 1 of 1 Posts
2.0L Theta
In-line 4 All aluminum block & head. DOHC with variable valve control(VVT)
144hp/5800
19.4kg-m(140lb-ft)/4000
Won't be available in US
2.4L Theta
166hp/5800
23.0kg-m(166lb-ft)/4000
3.3L Lambda
V-6 All aluminum block & head. DOHC
230hp/5800
31.0kg-m(224lb-ft)/4000
Will be put on New Sonata and Grandeuer (Code name TG; XG for US market)
3.8L Lambda
Max power said to be around 260hp.
The numbers are Korean spec. US & EU numbers might vary.
The in-line 4 engines will be shared by Mistubish & Chrysler in 2005.
1 - 1 of 1 Posts
