Hello,
I have been facing the problem since 2 days after having my Battery replaced ( which i replaced wid the same brand n specs with one i had used before ) whereby My transmission has been stuck on 3rd gear. Which i switch it to manual, it shows 3rd gear but when i switch on to acc mode ( before the ignition ) it say 1 which it suppose to be and then when i switch it to N and start, it come back to 3rd gear.
I have checked my transmission oil level which is perfectly fine n is used so far for 9k after my last change.
I have had swap the horn sensor with the atm cont sensor in the sensor console since both sensors ar 12v-20 but issue persist. Tried to reset the battery few times but no luck so far.
I still need to scan the TCM to get the error codes but i have had the similar issue precisely a year ago and as far as i remember, it automatically got fixed in 2 to 3 days time. At the time i did had a scan after the issue was fixed automatically n had the error codes reset n then i had my transmission oil changed too.
Has anyone here faced a similar issue ? Perhaps an insight would be great on this
Thanks
Need the codes....
Regardless of what the indicator says, are you really in 3rd gear?
If you give it gas does it move?
Can you shift any in manual mode?
Did you get resolution? My 3.3 got stuck in third around 170k miles. It'd go 1-5 normally unless I idled around 30-40mph then it would jump or drop into 3rd and stay there until I restarted the car. I was hoping it would be electrical or something stupid but multiple places told me I had to replace the trans. (autozone, 3 diff mechanic places). Also my reverse wasn't working (around same time) drove it like this til around 200k... Got a 60k trans put in for 1500$ worth it IMO.
