Hello
On my 2000 Sonata EF, I have a problem with a hatch which control the air intake or circulation.
In fact, the most likely the problem is in the 9710838000 ACTUATOR-INLET DR.
When I press the "internal air circulation" button on my AC control unit, I hear beep, button LED will light up, but nothing happens,
But since this inlet actuator is completely "hidden" and inaccessible (the bolts), I ask you for detailed instructions how to replace it.
Thank you in advance, greetings!
Similar experience in my Explorer blend door actuator. I used a cut 8mm wrench because nothing else was fitting in there (and able to rotate).
On Sonata I didn't have yet the "pleasure"...
