· Registered
Hello, im working on a 2003 Hyundai Sonata 2.7L V6 A/C unit. So I removed the compressor, took it apart to clean and lube the bearing and lost both the little washer that is behind the clutch plate as well as the snap ring that went shooting off somewhere.
Is there anyone that can help me identify the correct size of both the little washer and snap ring? It appears the snap ring has an inner diameter of 1 1/8. Is this correct? Thanx in advance!!
· Registered
Discussion Starter · #2 ·
Nevermind, I ended up figuring it out.
It is 1 1/8" (inner diameter) on the "thin" snap ring and it is a 10mm (outer diameter) on the "thin" washer. Most of the ones they have at the hardware store are too thick and the inner diameter is too small. I had to go to a specialty nut and bolt place. This posting is just in case if anybody else needs it in the future, thanks
