Hi, I bought a Sonata 2006 a month ago and the alarm is activate automatically a lot of times during the day, even if I just lock the car manually. Any suggestions will be appreciate.
maybe the lock switch of the door or trunk is bad, or they can't close properly. Spray some wd40 lubrication on door/trunk latch
Suspect number 1 be hood switch pad at hood.. original part been updated across the board with with a thicker pad to more firmly push on hood switch... a lot of times, the car been wrecked,, with hood replacement,,, body shop not install hood pad for switch too
We generally have 4-6 of them in stock,, cost all of $1.50, takes maybe 10 second at most to replace
I had this issue before. It was a defective keyfob. I had it sitting on the table and saw the light flicker and then my alarm turn on without me touching it. I replaced the battery and the same thing happened. I finally took the battery out and just kept using the other one. I hind sight, I should have taken it in to the dealer and had them replace it while it was still under the bumper to bumper warranty.
