1 - 9 of 9 Posts
hello everyone
i have a 2006 sonata nf l4 automatic.Since past month i am hearing transmission whine when gear changes from 1st to 2nd.The noise only occurs when the car is driven sedately.like when the RPM is 1800 and the gear changes the whine is there.
the car has clocked 1,06,000km.
I'm not an expert by any means but I would start with a drain and refill of the fluid, try castrol multi import transmission fluid. Make sure the levels are proper. There is a thread here on the process. IMHO "whining" is usually a bad thing. If that doesn't help post us again
1 - 9 of 9 Posts
