When applying the brake the main cylinder "snores" and the car only brakes on 1 of the 2 circuits.
Could it be the main cylinder seals? If so, can one get just the seals or should I get another maincylinder?
Cheers
Discussion Starter #2
Have bought a rebuild-kit today so I'll start with that. The car draws brake fluid but dont leak it anywhere visible so I assume the seals are bad in the main cylinder.
Apparently it leaks into the vacuum brake booster. And burns your brake fluid in the engine.
Personally I would install an all new master cylinder. No experiments there. Very likely the cylinder bore is bad, too - which makes the seals fail.
