1 - 1 of 1 Posts
Hi there!
I've been having problems with my Aussie Lantra J1 93.
It stalls in low revs, dies when stopped on Drive position and smokes a lot.
I've found low compression values on all 4 cylinders (under 50 Psi) and it didn't increase when oil disbanded to the cylinders.
I was hoping it could be some timing problem because the timing belt was changed a short time ago for the previous owner but all marks are matched.
Now I'm thinking in finishing removing the head to check the gasket and valve seals.
I just wonder if anyone has had any similar experience to tell me because the smoke coming from the oil dipstick doesn seem to be related with any upper engine problem but I guess the rings are still alright because the compression didn't built up with the oil.
Hope hearing from u guys soon.
Cheers
1 - 1 of 1 Posts
