I have no lights on my dash and no white smoke coming out of my exhaust and i cant find any leaks dropping under the car, anyone have any idea where this could be coming from ?
Thanks.
A small fuel leak can do this. I had this happen on a BMW and it ended up being the fuel filter connection dripping onto the lower control arm, where the fuel was evaporating. Difficult to diagnose (took me about 6 weeks to finally locate it).
If it is raw fuel that you smell, if it it under the hood, check all the fuel fittings. Even if you don't see a leak, you may see a dirty fitting where the fuel is causing dirt to stick. If the smell is stronger in the back of the car, it could also be an Evap system issue.
Good luck!
