wishing to upgrade the lights of a 69 registered I10 have fitted Phillips extreme vision headlights which have made quite a difference to beam pattern but slightly confused as to the access for the side/position lights and would appreciate any comments.
Thanks
Remove the cap from the back of the headlamp and you should see the side lamp bulb holder with the green and black wires right beside the headlamp bulb. Just pull the bulb holder rearwards and it will come out. I think it's a 501 capless bulb.
Sorry for delay in responding with thanks. Followed your instructions and found the bulbs but depsite pulling they will not pop out and the only thing to get a good grip on are the wires which I am loath to pull very hard. Any further comments appriciated.
Julian
Be aware that your insurer will see this as a modification and, if not declared, could result in them refusing to pay out if you're involved in an accident.
