2015 Santa Fe XL limited - Recently I noticed my passenger side rear turn signal was out. I went to replace it and found it was fine. I decided to check all exterior lights and found the turn signal on the passenger side also does not work. I would like to check that bulb but am having a difficult time locating instructions online how to get at it. I don't want to just do it and risk breaking clips etc. Anyone have to get a this bulb before, any tips? Thank you.
Feels odd even posting for help to change a bulb lol.
Cheers,
~Merlin
If you're talking about the wing mirror indicators, they're LED and one assembly. Maybe you can pop the internal trim cover off the door in the corner and disconnect the harness. confirm there's voltage going to it and / or could test to see if the LED array is shorted but often if 1 led fail could take the rest of the array out
Not sure if this assembly is correct part number
87623-B8000 is this particular number . you would have to fully disassemble the mirror as this is screwed in behind the glass.
This part is fairly cheap from korea, maybe not so in the US
