Do you guys have any lights in this red section of the triangle like the front?
seems like a lot of wasted plastic other than a reflector.
There is a side marker light in the headlight. I replaced mine with a bright amber LED. In the tail light, there is a cut out in the panel behind the light assembly with a rubber grommet. I suspect a light can be added or is added there in other markets. Unfortunately, behind the reflective material is solid red plastic.
Where did you purchase the amber LED?? Would like to replace as well!
