I need help deciding which shocks/ struts to put on my Sonata. It's a 2000, GLS, 2.5L V6 and I need to replace both rear shocks. I keep seeing KYB this and KYB that, but I am curious about AUTO7's coil overs....what is a coil over anyway? This is what I've found...
ROCK AUTO
MANDO Part # EX5531138400 HYUNDAI / KIA OEM
EF Series, Rear, Left or Right, Gas
$26.79
AUTO 7 Part # 8650022
Coil-Over; Rear
$76.79
AUTO PARTS WAREHOUSE
KYB Rear Shock Absorber and Strut Assembly GR-2 - Shock absorber
Part number: KY341246
Manufacturer number: 341246
$79.27
Part number: W0133-1615857
Manufacturer number: W0133-1615857
$62.95
...Somebody....anybody...please help me. I'd appreciate it.
Get the KYB, should provide a better ride than the cheap OE shocks....
Word of advice --> Get all new mounting bushings, washers, sleeve, and nuts.. OE mounts were compressed foam, you'll likely find the top washer sitting on the bracket where the upper bush resides.... dealer "SHOULD" have that stuff on hand if they good, as it is a common replacement on XG and Sonata for clunking in rear... may consider sway bar bushings too, as after you firm up the suspension wiith struts and mounts, it'll bring out the slop in the sway bar bushing and clunk there when done.
QUOTE (kapitol7 @ Jul 24 2010, 07:04 PM) index.php?act=findpost&pid=344467
ROCK AUTO
$26.79
Coil-Over; Rear
$76.79
$79.27
$62.95
ive been using KYB shocks for a long time,,and it serves me very well..
