1 - 9 of 9 Posts
Do you think revving up the engine in neutral then shifting into drive from a stop will damage the transmission? Wouldn't it be similar to dropping the clutch in a manual?
2007 Honda CRV
Seeing that you asked the question means that you already have an idea of the answer
It will eventually do damage after doing that procedure for a while
Just like dropping the clutch in a manual transmission will cause a little damage
And over time, it will show in the form of slippage ... damage
Well, that is my opinion.
Just curious why you are asking. Not sure why anyone would do this.
I have.... Plans.....
It might include a cocky friend with a new base model Elantra who "installed" a turbo and I'm trying to prove him wrong, and also have a little fun
Depending on how high you rev the engine, you can definitely damage things. But, you can get a nice strip of rubber on the road. :)
You'll never see this done at a drag strip. For high RPM takeoffs with automatic transmissions, they use what's known as a transbrake. https://en.wikipedia.org/wiki/Transbrake
For the best launch with a stock auto, just load the torque converter by holding your foot on the brake and then apply the gas until the point where the vehicle wants to move forward. When it's time to go, let your foot off the brake and stomp the gas.
Lots of luck :)
lol. a neutral drop will ruin the auto trans... you're better off doing a brake stand. rev up the engine with the brake pedal engaged, then release the brakes.
and yes, dumping the clutch in manual trans cars is not a good idea either. You will burn up the clutch.
1 - 9 of 9 Posts
