Hi Everyone,
Yesterday the car drove fine 125,000 on it new battery and alternator less than a year ago. did a boost with the 80 amp starter still nothing. Only took 5 min to fully charge the battery. No engine codes. The only thing I have noticed lately is that the gear box is stiffer to change from park-drive-neutral, but the manual option is fluid. Is it possible that my problem is to do with the stiffness maybe not completely in the gear so it won't start? I am going to try to wack the starter this evening to see if that helps.
As I turn the key I do hear the electrical click but there is nothing when I turn it over, not even the click click click that happens when you battery is low.
Any Ideas?
Thanks,
Jason
Any Ideas?
Thanks,
Jason
