Ok.........I won't bore you with all the letters and words that connect these items....
2003 Santa Fe 2.4
GF calls SMC says car won't start can you take me to work.
I find the battery terminals are loose.
- tighten
- good
Cars been running rough
- change spark plugs
-runs but misfire.
-correct spark plugs
Replace two coil packs with tails
Replace two coil packs under controllers
-same problem, runs but rough and misfire.
(Meaningless swapping things around)
(Sudden realization)
Oh duh. I have 1 and three wired backwards.
-switch
-car starts, runs smooth
"Yeah!!!!!!"
(Ok, old spark plugs in motor, lets put the new ones in and be done with this.)
-change spark plugs
Cranks, but won't turn over now.
-replace with old spark plugs
-same
-no spark now
-put allllll new coils on
-same
2003 Santa Fe 2.4
- tighten
- good
-runs but misfire.
-switch
"Yeah!!!!!!"
-change spark plugs
-same
-no spark now
-same
Are you using Hyundai wires? If not I HIGHLY recommend you start with getting some and see if your problem clears up.
Still no luck. We are getting voltage to the ignition coils, but no spark. We have even replaced the coils and still no spark. What is the proper voltage to the coil itself? We are getting 3-5 on the low side and 8-9 on the high side. Is that what we should be seeing?
