The manual for my "other car" ( a ford Taurus) states at 7 different places not to use any additives whatsoever.
It's too bad Hyundai is silent on the subject.
I would use such additives only if I had nothing to lose. If the car is old and running terrible, you could getYeah, I totally advise against the Sea Foam thing. It screws up the O2 sensors and the cat. Show me a reason why you need it.... bad MPG? Best to leave well enough alone.
I watched youtube video and thought I'd try the Sea Foam intake throttle turbo cleaner. followed the can instructions and the tool to keep the spray hose in place on 2017 Accent resulted in the air-in-take boot not being able to be refitted with the attachment in the throttle body. So I had to hold the can with the air-intake-hose off (unlike the youtube video showed) .After the can emptied I followed soak instruction and the start and idle instruction and took the car out afterwards. Big plums of smoke had people pulling over. This eventually burned off but I now had check engine light. I have a computer monitor plugged in that ref. P0638 throttle actuator control range/performance Bank 1. There is a strong smell of gas or the sea foam chemical some 15 drive now and code still remains. I am not sure about sea foam and should of went with the CRC brand I believeFirst I saw that you added Sea Foam to oil. You should probably change the oil soon. I believe the directions are to add it to oil just before an oil change and then change the oil.
Putting small quantities as recommended in the fuel tank has no adverse effect.
As you learned, adding it into the intake through a vacuum hose (which is most effective) can cause temporary misfire with codes activated that have to be reset. I know that Subaru and possible some other car makers actually sell their own brand of essentially the same thing as Sea Foam and recommend it use as a "top engine cleaner." Based on that, I doubt that it would do damage if properly used.
