1 - 20 of 23 Posts
I have a line on a duel exhaust off an SE, do we know if it is a direct bolt in? Has anyone done this, an do u have pics
Yes it is I did the borla exhaust on my limited witch use to be single exhaust now it's dual and it went on with a simple bolt on u just need to get the extra heat shield and hangers from the dealer
As above by cabrera17. I had the SE factory dual system off a fellow forum member's Sonata installed on my 2.4 Limited. The only extras were the heat shield and hanger for the left side. Direct bolt up.
Bob
WHat advantages would there be for adding the stock dual exhaust? (other than aesthetic)
would you need a new bumper with the dual cutouts? I know my GLS has the single behind the bumper, Barely visible.
2 horsepower. LOL
Discussion Starter · #9 ·
Just the cosmetic look is what I want, I think the back looks much better with the duals. I don't really like the sound o aftermarket on a 4 banger, so this is good option
Besides Adding The Stock SE dual Exhaust On A GLS, does The GLS Bumper Also Need To Get Changed As Well To An SE Bumper to Accommodate The Dual Cut-out?
Discussion Starter · #18 ·
I'm going to wait to see how we'll the shop cuts out the bumper, if it doesn't look good ill get a diffuser. I think I'll be putting on dual tips too.
Discussion Starter · #20 ·
not worth the money from hyundai, need to find it at junk yard good luck. I ended up going another route with mine n did custom dual tips on factory muffler. you can see pics if you go to my profile. good luck
1 - 20 of 23 Posts
