I have been using a Santro LE (india) for the last 4 years (June 2000). the car has been sparingly used (done 21000 km).
Over the last 6 months i have a problem- the engine rpm increase when the clutch is pressed to shift gears. if the engine is switched off, the rpm becomes normal sometimes but not always. I was given to unserstand by the service centre that this is problem in Santro made prior to 2001 and that there is no permanant solution. I was also told that there was a modification carried out to the engine manifold and that retrofit is not possible.
Is there a solution to this or do I live this problem?
I am at Chennai, India.
regards,
unnikrishnan
regards,
unnikrishnan
[snapback]2704[/snapback]​
what engine is your car
