Have replaced the Glow Plugs
1)Remove Intercooler
2) Remove Engine Cover
3) Remove big pipe from Air filter and push back (do not need to remove it fully)
3) Remove Intake Turbo Charger hose
4) Use Masking tape to cover all Intakes from dirt/or bolts
5) Remove breathing hose and VGT actuator vacume hose (c)
6) Open 2 Bolts x 2 each sie of the intercooler PLUS additional bolt under it !
7)You can hold the ECR cooler back do not need to remove the water hoses
8) Remove the heat exchanger
9) You now have access to the glow plugs
I have schema diagrams of the parts to remove will try to load them also
