Please can any one help on how to replace the turn signal repeater for the 2013 santa fe sports. It got cracked. I have seen a replacement on Ebay, but I am wondering how to reomve the old one and replace it
Most of these should be similar but you will need to dismantle the mirror. Best done off the vehicle I think.
Basic sequence would be
  • remove the assembly from the vehicle
  • carefully pop the mirror off it's base, I suggest a flat.wooden spatula, tilt the mirror and pry right in the center where it clips into the motor assembly. If you put pressure on the glass there's a real chance it will crack
  • also expect there will be wires for the heater element
  • this will expose the inner cover, assume screws holding this in, remove
  • you should now see how the indicator assembly is mounted
i30 example
i30 example
Thanks, I am expecting the replacement part from ebay soon, was delayed cos of the virus pandemic, looks like an easy fix from the resources you have shared. I will let you know once I get it done, thanks again.
Hi all. Sorry to hijack the thread but I’m also trying to replace the repeater, on the passenger side. I ordered what I thought was the relevant part from eBay, but it’s arrived and whilst it looks identical, the part to plug in is male (ie 2 pins) whereas the repeater I have removed seems to be “female”. Are there different versions of the passenger side repeater part? Have I ordered the wrong thing?
