1 - 1 of 1 Posts
I am about to replace the fuel pump. But the Weird thing is When you turn the ignition to "run" the fuel pump is supost to run for about 2 seconds and pressurize the system. Mine is not doing that. I Have tested Voltage at the pump and it has constant voltage but non that stops after 2 seconds. Where should i start looking for that issue? Thanks for your help
1 - 1 of 1 Posts
