SENIOR MODERATOR
It can be a bit finicky but here is a step-by-step:
  1. Remove ashtray
  2. Locate two screws behind ashtray and remove them.
  3. Pull out lower stack (climate controls)
  4. On each side of the underside of the radio fascia, there will be two more screws. Remove these and gently pop the fascia loose from the bottom, working up.
  5. Disconnect the leads to the clock, fog, hazard and defrost switches.
  6. There should be two more screws holding the clock in place. Remove these and it will pop right out the back.
  7. Installation is, as they say, reverse of removal.
:thumbsup:
