I have a 2001 santa fe 6cyl 2.7L engine and my engine light is on. I'm reading codes P0715, P1529, P0300, P0303, P0305, and the weird one U2000
I need explain each code please. so i could fix it my s:confused:elf.
P0715, -- turbine shaft speed sensor fault (input shaft speed)
P1529, -- Trans control request to PCM asking for use of MIL to tell driver we have problem
P0300, -- random misfire detect, cylinder not specified
P0303, -- cylinder #3 misfire detect
P0305, -- cylinder #5 misfire detect
and the weird one
U2000 -- not familiar with that one.. no "U" codes called out in any of the SM' control units
Explanation supplied, now to diag each problem circuit and repair
A response from a dealer tec in 17 minutes , on your first post, how do you top that, not likely.
How old are your plugs, have wires
ever been changed, start with the cheap obvious stuff.
Indeed, your P codes seem to point at misfire detection and the like.
U codes refer to bus or other communication problems within the control system.
U2000 means: Audio Rear Control Unit is Not Responding
I think this refers to the audio power amplifier in the rear.
Good luck,
Paul
