When driving the power just seems to drop down with no warning and i have to wait till the engine kicks in again before i can move again. When this happens i try to give it some acceleration but nothing happens. Had the turbo shaft replaced and still the same thing. Yesterday can moving a very slow pace and then cut out. Anybody know why this is happening???
Have you had the engine ECU scanned to see if there any trouble codes logged that might explain why the engine is dropping down? It could be something silly like a faulty brake pedal switch. That can cause the engine speed to be fixed at approx 1500RPM and it wont respond to throttle inputs.
